It is currently Thu Oct 01, 2026 9:24 pm
 Post subject: Read only , if you have a lathe -
PostPosted: Sun May 29, 2011 1:55 pm
and if you can handle it . Piston blanks for 69 to 72 mm , specially made for Bugatti . You can machine any dimension you like . This blanks are cast in a preheated mold and 2 times heat treated . material
Mahle 124 , the best material for pistons today . Any questions ?
 Post subject: Re: Read only , if you have a lathe -
PostPosted: Sun May 29, 2011 4:36 pm
None that I can think of.
PostPosted: Sun May 29, 2011 4:55 pm
I have a question...
You are selling them?
PostPosted: Sun May 29, 2011 5:33 pm
yes , this is the first mold we made for Bugatti . We make pistons from 58mm to 160mm .
PostPosted: Sun Jul 17, 2011 11:16 am
Are you suggesting that you machine your pistons on a conventional lathe?
PostPosted: Sun Jul 17, 2011 1:40 pm
yes , I use a conventional lahte .
PostPosted: Sun Jul 17, 2011 10:05 pm
So I guess the pistons you produce are round?
PostPosted: Mon Jul 18, 2011 12:28 pm
some engines have round pistons . But I do not make them round .
PostPosted: Mon Jul 18, 2011 12:34 pm
Machined on a conventional lathe but not round?
PostPosted: Mon Jul 18, 2011 12:43 pm
yes !
PostPosted: Mon Jul 18, 2011 8:31 pm
I've had that problem myself when I've used a dodgy old lathe too.... :wink:
PostPosted: Tue Jul 19, 2011 10:04 am
It is perfectly possible to make oval shaped parts on a lathe. However, you will need to rebuild your lathe somewhat. Udo already showed the principle in another thread. Inevitable play can be accounted for by tensioning the cross support with a spring.
Dodgy lathes should be refurbished, or tossed. However, even on a dodgy lathe a good craftsman can make accurate parts. As long as you keep all play to one side of your measurements and fixed points. Besides that, no lathe is free of a certain degree of play or backlash. Even with anti-backlash nuts. CNC programs take backlash into account when calculating the neccesary movements.
For peace keeping: Play it nice!
PostPosted: Tue Jul 19, 2011 12:08 pm
I agree.
Users browsing this forum: No registered users and 347 guests
