It is currently Fri Oct 02, 2026 9:23 am
 Post subject: The early Bugatti Patents
PostPosted: Wed Jan 07, 2009 8:07 pm
I am investigating all the Bugatti Patents, which will hopefully culminate in a book. There are currently over 750 patents, from many different countries (Germany, France, GB, USA, Denmark, Belgium, Austria, Canada, Switzerland, Spain). Most patents are of course by Ettore, quite a few by Jean, but there are also patents by Carlo and Roland.
Now, my question is the following: I have difficulty finding especially the early German (also the very early French) patents. The early German ones I have are:
DE158066 1904 Zerlegbarer Kurbelarm
DE167618 1905 Innenradbremse für Motorwagen
DE170691 1905 Ventilsteuerung für Explosionskraftmaschinen
DE203453 1907 Andruckgetriebe für Bremsen und Kupplungen
DE273247 1918 Lagerung der Motorwelle von Kraftfahrzeugen
DE332778 1921 Vergaser mit doppelter Regelung des Lufteintrittsquerschnittes
Early French ones:
FR461836 1914 Jonction de chassi monté sur ressorts d´avant
FR473605 1914
FR474536 1914 Dispositif de coussinets supportant l'arbre moteur dans les véhicules à traction mécanique
FR503441 1920 Dispositif permettant l'aménagement dans un carter de moteur, d'une bouche à feu tirant à travers un arbre porte-hélice
However, I know that there were quite a few more, especially German ones before WW1 (so up to 1914).
Does anybody have more info about these? What I basically need are the numbers only, but of course more info would be very welcome!
PostPosted: Wed Jan 07, 2009 8:20 pm
I know that in those days a lot of crossovers of technologie took place. Read the magazine Het Automobiel Jan.2009. Story of Stutz Black Hawk Mr Moskovics and Bugatti.
PostPosted: Wed Jan 07, 2009 8:43 pm
There are 2 sets of patents available on Ebay.
One is a CD which you probably have, otherwise contact me, the other is a set of "original" transcripts, they are yours for a "bargain". :wink: Sell your scale models, and you are almost there...
Isn't there a search facility for patents? I recall something like "espacenet". Or don't they go back far enough?
PostPosted: Thu Jan 08, 2009 8:43 am
There is a lot in Espacenet, and they even go back far enough (the patents on the CD have been retrieved from there also). Problem is that the earliest patents are not searchable. The scan is there, but it is not catalogued, only the patent number is there, and the scan.... Not searchable though. Try it with the early German numbers in my former mail, no mention of Bugatti, or the title is made, the scan is perfect though.
So, if anybody has numbers, that's sufficient.
I'll get the Automobiel issue.
PostPosted: Thu Jan 08, 2009 11:00 am
OK, it is just about the numbers then. I recall seeing a list in a book, no idea of which book however. And I cannot reach my books at the moment. (bathroom ingredients in front of the book shelves, I hope the construction guy works quick).
Anyone else that recalls the list, and can retrieve it? Johan?
PostPosted: Thu Jan 08, 2009 11:09 am
I have not really found a list (yet), maybe one of the lesser known books, Tragatsch or so.
Of course the Magnum has an article on the Patents, which is a reprint of the lecture he held for the Newcomen society. Some of the other books occasionally mention them, with usually a few numbers only.
PostPosted: Fri Jan 09, 2009 12:26 pm
Here is a list of patents, for sale on Ebay:
1911:
21159 Improvements in and relating to valve packings
21160 Improvements in and relating to the resilient mounting of vehicle bodies
1913:
3430 Improvements relating to wheel hubs
7131 Improvements in and relating to the resilient mounting of vehicle bodies
19655 Improvements relating to the arrangement of the cooling water
pumps of explosion engine
19656 Improvements relating to the connection of steering swivels to
vehicle axles
19657 Improvements in laminated springs for the suspension of vehicles
20385 Improvements relating to the lubrication of the crank shafts of
internal combustion engines
20386 Improvements in and relating to shock absorbers for vehicles
20387 Improvements in and relating to shock absorbers for vehicles
20388 Improvements relating to the connection of vehicle axles with the
frame
27047 Improvements in connecting-rod bearings
1914:
1357 Improvements relating to the suspension springs of vehicles
1358 Improvements relating to the mounting of the motor shaft in
automobiles
2038 Improvements relating to shock absorbers
5407 Improvements in adjustable screw steering gear for motor cars and
the like
6530 Improvements in or relating to toothed gearing
8128 Improvements in relating to spring suspension for vehicles
12523 Improvements in relating to valve gear for internal combustion
engines and the like
100266 Improvements in the valve gear for internal combustion engines
101390 Improvements in or relating to internal combustion engines
101534 Improvements in or relating to engines arranged in groups
103115 Improvements in valve distributing gear for internal combustion
engines
105218 Improvements in fluid cooled internal combustion engines
106795 Improvements in horizontal lathes
126672 Improved engine valve
131652 Improvements in mounting of guns on aircraft
Bugatti, Ettore:
GB160439 Improvements in bearings for the driving shafts of
mechanically driven vehicles
GB159482 Improved mounting of a dynamo capable of acting as a starting
device in an automobile vehicle
GB159822 Improvements in valve guides and brakes
GB146866 Improvements in friction clutches
GB141693 Improvements in dash-boards for motor vehicles,
aeroplane and like machines
GB152903 Improvements in turning tools for turret and automatic
lathes and the like
GB601710 Machine for cutting and chamfering metal sheets
GB601605 Improvements in or relating to means for winding sails
for ships and boats
GB599319 Improvements in spindles for milling machines
GB598194 Improvements in or relating to milling or like machine
tools
GB597905 Improvements in or relating to capstan or turret
lathes
GB597656 Movement amplifying means and its application to
precision instruments
GB597002 Propeller shaft bearing assembly for ships
GB596045 Improved bearing and spindle or shaft lubricating
arrangement, particularly for machine tools
GB595773 Improvements in steering wheel axles for motor
vehicles
GB593503 Improvements in or relating to chucks
GB592609 Improvements in or relating to resilient suspension
devices for cycles and motor cycles
GB592565 Improvements in or relating to power transmission
systems
GB591731 Improvements in or relating to mounting of grinding
wheels
GB591521 Improvements in or relating to means for supporting
crank shaft bearings
GB591326 Improvements in or relating to boring, milling,
drilling
and like machine tools
GB590854 Improvements in or relating to the cylinders of
Internal combustion engines and the valve gear thereof
GB223545 Improvements in valve systems comprising a cooling
circulation
GB223213 Improvements in light valves for internal combustion
engines
GB223212 Improvements in pneumatic tyres
GB240826 Improvements in operating mechanisms for brakes or vehicle
steering wheels
GB399047 Improvements in suspension of railway cars and other rail
vehicles
GB222477 Improvements in engine combinations comprising readily
removable elements
GB222478 Improvements in pneumatic tyres
GB222476 Improvements in or relating to motor vehicles
GB222475 Improvements in ball or roller cages for ball or
Roller bearings
GB220284 Internal combustion motor
GB218236 Improvements in carburetters
GB212866 Improvements in internal combustion engines
GB211877 Improvements in transverse spring suspensions for
vehicles
GB205488 Improvements in and relating to the spring suspension
Of motor vehicles
GB205089 Adjustable spindle for multiple drilling machine
GB205088 Improvements in carburetters
GB201160 Steering device for motor vehicles and the like
GB197928 Internal combustion Engine with Overhead Valves
GB197922 Lubrication of crank pins and the like
GB195392 Improvements in pressure lubrication for ball or
Roller bearings
GB461573 Improvements in or relating to cam motion transmitting
devices
GB458974 Improvements in devices for fixing glass panes,
panels, and similar flat elements in a frame or support
GB456476 Improvements in power transmitting mechanisms for
vehicles and especially railroad vehicles
GB451753 Improvements in or relating to crankshafts
GB450347 Improvements in or relating to reciprocating pump
control mechanism
GB449129 Improvements in furnaces fired by liquid or pulverised
fuel
GB446148 Improvements in or relating to cylinders of internal
combustion or other engines
GB446003 Improvements in or relating to vestibules, more
particularly for railway vehicles
GB444143 Improvements in or relating to axles for motor
vehicles
GB419168 Improvements in or relating to seats for use in road
Or rail vehicles
GB419029 Improvements in radiators for motor vehicles
GB416833 An elastic wheel for vehicles
GB411019 A vehicle wheel with metal spokes
GB409990 Improvements in or relating to automobile dashboards
GB409968 Improvements in or relating to shock absorbers
GB405205 Improvements in or relating to front axles for
automobile vehicles
GB404175 Improvements in or relating to bodyworks
GB403553 Improvements in elastic wheels for railway vehicles
GB401143 Improvements in or relating to vehicles rolling on
tracks or rails
GB400841 Improvements in vehicle suspension devices
GB396578 A device for supporting two or more rotating shafts
GB386954 Improvements in hydraulic brakes
GB386949 Improvements in hydraulic valve operating mechanism
For internal combustion engines
GB364074 Improvements in systems of mounting the fly-wheel on
The shafts of thermic engines, especially of multicylinder explosion
Engines for propel
GB349353 Improvements in system of mounting of the fly-wheel on
the shafts of thermic motors, and chiefly of multi-cylinder explosion
engines for pro
GB342390 Improvements in brakes with automatic taking up of
play
GB301375 Improvements in or relating to the mounting of vehicle
shock absorbers
GB301065 Improvements in devices for retaining water in the
radiators of motor vehicles. Or internal combustion engines
GB298193 Method of securing shock absorbers for automobiles or
like vehicles
GB283206 Improvements in safety devices for brake control
GB279116 Improvements in compensating links for braking
purposes
GB271435 Improvements in suspension arrangements for vehicles
GB270700 Improvements in noiseless controls for valves
GB257247 Improvements in multiple tool-carriers for turning-
lathes and like machine tools
GB256615 Improvements in thrust collars for valve spring,
Adapted to cover the valve guide
GB615309 improvements in or relating to Milling machines
GB543389 Cam mechanisms for operating the valves of internal
combustion engines
GB540206 Improvements in hollow bodies and methods of
manufacturing the same
GB539711 Improvements in means for co-ordinating the movements
Of rotation of rotating elements
GB527550 Improvements in or relating to the actuation of
Control surfaces on aircraft
GB527549 Improvements in or relating to actuating and
Controlling movable parts of aircraft
GB526461 Improvements in or relating to means for cooling
aircraft engines or engine radiators
GB526460 Improvements in or relating to the power plants of
aircraft
GB524836 Improvements in and relating to watercraft
GB524128 Improvements in and relating to bearings
GB500679 Improvements in and relating to screw propellers
GB497682 Improvements in or relating to lath-fabrics
GB496524 Improvements in boats
GB493239 Improvements in or relating to coupling apparatus for
vehicles
GB489073 Improvements relating to frames for railway
Vehicle trucks
GB484765 Improvements in devices for fixing glass panes, panels
GB483669 Improvements in or relating to chains
GB482553 Improvements in vehicles adapted to run both on roads
and on rough ground
GB482315 Improvements in or relating to bolts, studs and the
like
GB481339 Improvements in reciprocating piston engines
GB480497 Improvements relating to vestibules and like
Connecting structures for railway and like vehicles
GB475907 Improvements in trucks and wheel trains, especially
intended for railroad vehicles
GB473580 Improvements in or relating to swivel joints for
pipes, rods or the like
GB472242 An improved method of jointing tubes to tube plates
And the like
GB468110 Improvements relating to reversible seats
GB236585 Improvements in vehicle wheels with pneumatic tyre
casings with or without a separate air chamber
GB235854 Improvements in vehicle wheels with pneumatic tyre
casing with or without an air chamber
GB235541 Improvements in dismountable crankshaft for one-piece
piston rods
GB235168 Improvements in the method of manufacture of light
Front axles for motor vehicles
GB234783 Improvements in attaching devices for pneumatic tyres
GB233673 Improvements in attaching devices for pneumatic tyres
GB233324 Improvements in vehicle wheels with cooling disc
GB232229 Improvements in tool holders for cutting off pieces of
work
GB232228 Improvements in crankshafts
GB617398 Improvements in or relating to heat exchange apparatus
GB614915 Improvements in or relating to machine for bending and
shaping rolled irons and the like
GB612816 Improvements in crankshaft turning lathes
GB605571 Improvements in or relating to grinding machines and
tailstocks thereof
Bugatti, Jean:
GB508679 Improvements in or relating to vehicle suspension devices
GB459221 Improvements in or relating to hydraulic suspension
especially intended for vehicles
GB457279 Improvements in or relating to valves
GB446474 Improvements in or relating to lubricating devices for engine pistons
GB444286 An improved valve
GB440922 Improvements in means for removing leakage fluid from engine and like cylinders
GB417844 Improvements in or relating to the suspension of railway cars and other rail vehicles
GB396584 A method of elastically Securing the body of a vehicle to its chassis
GB396263 Improvements in driving gear For vehicles
GB394877 Improvements in railway trucks
or bogies
GB528356 Improvements in and relating to Railway vehicles
GB440198 Apparatus for testing the resistance of structural parts,
particularly parts of aeroplanes
Bugatti, Roland:
GB632728 Improvements in relating to for internal combustion engines
PostPosted: Sat Jan 10, 2009 11:11 am
Thanks for this list, Herman. It wouldn't surprise you that I already have all of these (and a few more).
What I am asking for are especially the German (DE) and French (Fr) patents, especially form before 1914!
PostPosted: Tue Jan 13, 2009 10:36 am
Over 750 patents!? Anybody knows how many patents there were, counting all of them together??
And of course, many patents in different countries were identical, how many basic patents were there? 250, 350??
And, what patent did Carlo hold? I saw some of the Roland patent (4 cylinder engine with rotating head), but what did Carlo invent?? Some special piece of furniture??
