It is currently Thu Oct 01, 2026 7:11 pm
 Post subject: De Ram
PostPosted: Sun Jun 15, 2014 2:14 pm
Who has any info about De Ram ?
 Post subject: Re: De Ram
PostPosted: Tue Jun 17, 2014 12:00 pm
Maybe I did ask in à wrong way . Do you guys know what à De Ram is ?
PostPosted: Tue Jun 17, 2014 12:17 pm
:D :D :D :D :D :D :D FACTFILE – Bugatti Type 59
Produced/number built 1933-’36/six Construction beam chassis, magnesium body Engine front-mounted, iron block and head with alloy crankcase dual-overhead-camshaft 3257cc straight-eight, with two valves per cylinder, six plain bearings, Roots supercharger, two Zenith 52mm carburettors and Scintilla Vertex magneto Max power 250bhp @ 5000rpm Transmission separate central four-speed gearbox, driving rear wheels Suspension: front live axle with semi-elliptic leaf springs and de Ram shock absorbers rear reversed quarter-elliptic leaf springs, radius arms and de Ram shock absorbers Steering worm and wheel Brakes cable-operated drums Track 4ft 1?in (1251mm) Wheelbase 8ft 6?in (2597mm) Weight 1650lb (748kg) Wheels piano-wire style with 6x19in tyres 0-60mph 6 secs Top speed 160mph
Maybe :?: :?: :?: :?: Perhaps
PostPosted: Tue Jun 17, 2014 12:20 pm
The de Ram damper used a metallic multi-plate disk stack, with alternate disks splined to either an inside or outside cylindrical carrier, much as for multi-plate clutches of the time.
Owing to the weight of the casing, de Ram dampers were always mounted to the chassis, with a single arm to the axle.
PostPosted: Tue Jun 17, 2014 1:09 pm
57 and 59 had De Ram , always or only sometimes ?
Any other Bugattis used De Ram ?
Has anybody an old De Ram catalog or something like it . It looks to me there are different kind of De Rams .
PostPosted: Tue Jun 17, 2014 5:37 pm
PostPosted: Tue Jun 17, 2014 9:50 pm
http://archive.motorsportmagazine.com/a ... k-absorber
PostPosted: Wed Jun 18, 2014 8:02 am
Thanks, Barttore and Jaap :D
PostPosted: Wed Jun 18, 2014 3:02 pm
The 57S has different de Rams compare to the late 57S like the Lauren Atlantic . Or is maybe only the de Ram housing different ? What about the story that the front axle de Rams are different compared to the back axle ? How is the availability , are they easy to get . It looks to me they are difficult and almost impossible to get . And nobody has any real 57S de Ram info . Is there a de Ram workshop manual ?
PostPosted: Wed Jun 18, 2014 6:32 pm
https://www.flickr.com/photos/grahamlittle/3307739808/in/pool-1018478@N22/
http://www.flickr.com/photos/grahamlittle/3325571006/
https://www.flickr.com/photos/grahamlittle/3306475132/in/pool-1018478@N22/
PostPosted: Wed Jun 18, 2014 7:02 pm
This pictures show a 57S front axle de Ram , will not fit a late 57S like the Lauren car . Do we have a Forum member who owns a de Ram ?
PostPosted: Thu Jun 19, 2014 12:30 pm
The Motordport Magazin has some interesting info . But it looks like there is not more knowlige in the Forum about the De Rams . And nobody has one . I am especially looking for info about the very late 57S De Ram , like the Lauren Atlantic .
I discovered , that Bugatti made his own De Rams with parts from the De Ram company . Again , he wanted something , nobody else had . And I am sure he was the only one with this kind of design .If anybody has some interest , I can show a little about this De Rams . How much I have found out till now.
PostPosted: Thu Jun 19, 2014 2:56 pm
Bugantics Vol.21 No3 page 13-21.
very interesting article about de Rham shocks for 57s.
Written by an Englishman engineer so probably not worth the paper its written on...
I would copy and upload it, but I simply can't be arsed.
PostPosted: Thu Jun 19, 2014 6:52 pm
Hello Greg , nice to see you are still alive . Do you have any info about de Ram ?
Written in 1958 , so maybe it is worth the paper .
PostPosted: Fri Jun 20, 2014 10:26 pm
All the reading about de Ram does not really help . Best to take one apart and study the inside parts .
Uwe , do you anderstand the table you posted ?
