It is currently Thu Oct 01, 2026 10:16 am
 Post subject: Location engine number Type 57 on cast iron cylinder block?
PostPosted: Sun Mar 16, 2014 4:48 pm
Is it correct, that underneath the cast iron cylinder block of a Type 57 the engine number is located in the middle of the eight outlets (between fourth and fifth)?
On my block, I find three different numbers at the place described above. One with three letters, below another with one, and one with two letters.
Thanks for your input!
 Post subject: Re: Location engine number Type 57 on cast iron cylinder blo
PostPosted: Mon Mar 17, 2014 5:25 pm
for example
110
2
38
I think this are casting numbers and not engine numbers
PostPosted: Wed Mar 26, 2014 9:38 am
What numbers do you have ?
PostPosted: Wed Mar 26, 2014 12:23 pm
my numbers are:
410
2
36
I think the first number could be the motor number; the second maybe the series number; the third could be a casting or production number.
Thanks for your information!
PostPosted: Thu Mar 27, 2014 2:39 pm
I am not so sure about the engine number . I think the last number is the year , like 1936 and 1938 . No idea about the number in the middle . I have more blocks , I will look .
