It is currently Fri Oct 02, 2026 9:57 am
 Post subject: Update on my Build
PostPosted: Mon Mar 04, 2013 5:10 pm
Sorry its been so long since I've posted up here. I have made some good progress and am in the final stages of re-assembling the car for good this time.
I am also making and selling frames and aluminum bodies / Body panels if anyone is interested.
You can see a very basic website of mine (under construction) at
http://www.sterantino.com
 Post subject: Re: Update on my Build
PostPosted: Sun Mar 10, 2013 11:11 pm
how much is missing to put the engine in the frame ?
PostPosted: Mon Mar 11, 2013 2:07 pm
Nothing (for the Alfa drivetrain I am using). There is a motor mount crossmember already in place, and the backend of the transmission mounts to the forward split-tube crossmember. If I were to use a Bugatti drivetrain, I would have to modify the split tube cross-members for the gearbox.
PostPosted: Mon Mar 11, 2013 4:17 pm
try the Alfa engine first . I like to see how it looks .
PostPosted: Mon Mar 11, 2013 7:10 pm
You should look at my friends site Udo.He is making a T37 with Alfa engine,he also has Alfa single seaters made from modern parts., http://www.forum-auto.com/automobiles-m ... -28070.htm
PostPosted: Tue Mar 12, 2013 3:01 pm
Heres a pic with the Alfa in it. Fits really well and the oil pan fins stick through the belly pan which looks great.
PostPosted: Thu Nov 28, 2013 5:28 pm
Happy Thanks Giving to all my American friends.......Finished up my radiator last night....figured I would share. Yes I know its Brass...not nickel - Yes I meant to do it that way....because I wanted to....etc, etc, etc...
Dan
