It is currently Thu Oct 01, 2026 4:05 pm
 Post subject: Re: Atlantic question
PostPosted: Mon Jun 11, 2012 10:23 pm
OK , my mistake . Both chassis are T57s . Top foto chassis has a crossmember with a mounting for the engine and gearbox . bottom crossmember has no mounting . Why ?
PostPosted: Mon Jun 11, 2012 10:40 pm
Sorry udo on my iPad I can't see what your photo shows. Are you looking at the difference between solid mounted 57 engins and later rubber mounted 57 engins?
PostPosted: Tue Jun 12, 2012 1:42 am
I think your qustion is my answer . So early 57 have a solid mounted engine and later ones are rubber mounted . How looks the solid mounting ? It looks like the one on the foto with the rubber is a late conversion original it was a solid one .
PostPosted: Tue Jun 12, 2012 9:35 am
Changing fron solid mounted to rubber mounted would require a crankcase change as the solid mounted T57 engines were fixed on 4 points to the chassis.
None of these early crank cases had a compressor drive if I'm well informed.
As reproduction parts I only know rubber mounted crank cases from C&G.
Greetings:
minime
PostPosted: Tue Jun 12, 2012 12:25 pm
Early solid mounted engine
PostPosted: Tue Jun 12, 2012 12:28 pm
late ruber mounted engine this one is an S
PostPosted: Tue Jun 12, 2012 2:05 pm
I think , this 57 chassis is converted from solid to rubber mounts at the rear . Look at the holes in the chassis . The mounting plate went some cm forward . How looks the front engine mount ? How is it bolted to the chassis ?
PostPosted: Tue Jun 12, 2012 2:12 pm
not sure.
its moved but not sure why? what is the year or better the # then you will know what was the original engine.
PostPosted: Tue Jun 12, 2012 3:56 pm
It looks moved but not converted from steady to rubber mounted.
The steady mounted engine is fixed further in the front with 4 bolts per attachment.
There are also some other differences for the cross members of the chassis (at least for the standard T57 chassis).
On early T57 with steady mounts it's for example possible to remove the gearbox without removing the engine what apparently can't be done on the rubber mount chassis.
minime
PostPosted: Tue Jun 12, 2012 4:12 pm
As it looks like it has been moved forward is it possible or likely that some time in its life it was a blown(supercharged) car that has subsequently been altered?
PostPosted: Sat Jun 16, 2012 2:37 pm
What about the wheels ? All Atlantic have the same wheels ? Or all 57 have the same wheels ?
PostPosted: Sat Jun 16, 2012 8:25 pm
http://www.bugatti-trust.co.uk/bugatti-cars/index.shtml
PostPosted: Sat Jun 16, 2012 8:34 pm
Bugatti Trust , Rudge wire - 18x5,5 thats all .
How many spokes in how many rows . How many splines in the hub .
PostPosted: Sat Jun 16, 2012 9:07 pm
Type 57 S./S.C.
18 x 5.50 front
18 x 6.00 rear
PostPosted: Sun Jun 17, 2012 12:18 am
this is the tyre size , but what kind of wheel is it ?
Users browsing this forum: No registered users and 221 guests
