It is currently Fri Oct 02, 2026 7:57 am
 Post subject: Water Pump
PostPosted: Thu May 10, 2012 11:18 pm
 Post subject: Re: Water Pump
PostPosted: Thu May 10, 2012 11:19 pm
PostPosted: Fri May 11, 2012 1:30 pm
I even bore myself by once again saying:
Udo, your water pump is completely wrong.
PostPosted: Sat May 12, 2012 6:13 am
Would it matter, if it is fitted onto a rear-engined Galibier powered Royale?
PostPosted: Sun May 13, 2012 12:39 am
all the drawings went to the pattern maker , let's see what happens .
PostPosted: Sun May 13, 2012 10:54 am
Well that will be money wasted then, as I think I said once before- its wrong.
PostPosted: Sun May 13, 2012 12:18 pm
I would have thought that buying the original patterns for water pump that I put into the goodwood auction would have been a good plan :D They sold for peanuts.
PostPosted: Sun May 13, 2012 3:36 pm
I cannot see such a big difference and I do not have the time to watch this project to all the little details .
I can not remember to have seen anything what you made ?
PostPosted: Thu May 17, 2012 9:09 am
Original aus molsheim.kauft 2011 Goodwood.
PostPosted: Sat May 19, 2012 8:46 am
If you were so keen to have a water pump for Royale you should have bought mine..........I thought to use it to pump wine up from the celler.
PostPosted: Mon May 21, 2012 3:01 pm
advantage JB ;-)
PostPosted: Sun May 27, 2012 5:05 pm
I will cast one in bronze and polish it to use for decoration !
