It is currently Thu Oct 01, 2026 7:36 pm
 Post subject: 37234
PostPosted: Thu Feb 23, 2012 5:56 pm
http://www.bugattiregister.com/wiki/ind ... itle=37234
Quote:
Type 37 Sport, then 37A (body Grand Prix), now 37
In dem Fahrzeug war defintiv nie ein Kompressor verbaut. Die Motorhaube ist definitv original und weist z.B. keine Spuren eines Kompressorloches auf, ebensowenig sind die notwendigen Bohrungen im Chassis (z.B. zum Zurückversetzen der Lenkung) vorhanden. Wie es zu der Annahme kommt dass es sich um einen 37a handelt ist mir unklar.
Martin Strohhammer
 Post subject: Re: 37234
PostPosted: Thu Feb 23, 2012 7:44 pm
Original article:
http://www.motor-klassik.de/oldtimer/bu ... 84773.html
English version:
http://www.bugattirevue.com/revue41/old.htm
This sentence
"....he had however not - as was written later - converted the car to a type 37A , or mounted a compressor on car number 37234"
is not translated correctly. The original version
"er hatte dazu aber weder - wie später immer wieder geschrieben wurde - auf einen Typ 37A mit Kompressor umgesattelt, noch einen Lader in den Wagen Nummer 36234 eingebaut."
says not "converted to" but "changed against", meaning that Ollendorf during all his career, and later also Karl Wagner, raced #37234. The car as survived today is an unsupercharged T37, and there are no signs that at any time a compressor was installed.
The photo from the Avusrennen 1931 shows Ollendorf's car (#16) with a pressure relief valve hole in the bonnet, and I have another one of Wagner at the Nürburgring in 1932 also with a hole. Also there are period newspaper race reports mentioning Ollendorf's "Kompressor-Bugatti". The history of 37234 does not include the registration IM-3333 (Saxony) as visible on the AVUS photo, only IIA-3926 (Munich) and IA-42314 (Berlin).
So obviously Mr. Strohhammer is wrong by reporting only one single Bugatti - 37234 - for Ollendorf. The history of his car without any doubt is correct until 1930, and also that after the war. However, the period 1931/32 covers a different car, in fact a T37A of unknown identity which Ollendorf changed against the old T37. Probably Hans Simons of Berlin was involved in both cars, because he made a living with the trading in T37's. Most German competition T37/37A at one point or another went through his hands.
PostPosted: Fri Feb 24, 2012 10:12 am
Thank you Michael Müller for this information. They make it possible to update Wiki.
