It is currently Thu Oct 01, 2026 7:32 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: cilinder block T35-37
PostPosted: Thu Oct 06, 2011 6:52 pm
Don't know what you mean by the wall - do you mean the water jacket?
PostPosted: Thu Oct 06, 2011 8:36 pm
PostPosted: Thu Oct 06, 2011 9:37 pm
What will become a void for water,starts out as a "wall of sand" being the thickness of the water passage.I dont know how to make it simpler.
PostPosted: Thu Oct 06, 2011 11:56 pm
rapid prototyping is a affordable way to get a high prezision mold for sand casting . For sure , there are better ways to cast a Bugatti cylinder block . But who is willing to pay for ? One of you guys ? :wink:
The best way today is to have a ceramic mold ,heated up to about 1000 celsius and pure the hot metal in the hot mold .I for example make my con rods this way .It would be the best Bugatti cylinder block ever made , and the most expensive one . But as long nobody is willing to pay for this quality you have to live with the cheap production line .
PostPosted: Fri Oct 07, 2011 12:25 pm
As I said - the water jacket. For sure it makes things easier if the sides of the cylinder block are open enabling an extra print either side to lock in the sand core, as in the manner of the 41, 46, 50, 57 etc, but you still have a reasonable location for the core if it is given a large enough print on the open top face of the block. If there was demand I would happily make them, but it seems there are enough people doing them allready.
PostPosted: Fri Oct 07, 2011 1:56 pm
These T35/37 type blocks were cast upside down.Head downwards as it were.There is no location at all for the top [bottom] of the sand.Strength therefore depends on the sand between the ports each side.Obviously the print needs to connect all these points and be rigid.
PostPosted: Fri Oct 07, 2011 2:42 pm
It would be nearly impossible not to cast it upside down. If the side cheeks sat on top of the cod that makes up the upper water gallery/ ports and ths is wired into the lower water gallery then it is unable to float. allmost makes me want to make a GP block pattern just as an exercise... :idea:
PostPosted: Wed Jun 18, 2014 11:40 am
PostPosted: Wed Jun 18, 2014 11:47 am
