It is currently Sat Apr 04, 2026 10:04 am
 Post subject: Frame 54216: truth or not?
PostPosted: Thu Feb 24, 2011 1:02 pm
Built in Molsheim, yes or not?
Or number allotted subsequently on an existing frame?
See: http://www.bugattirevue.com/revue13/54.htm
 Post subject: Re: Frame 54216: truth or not?
PostPosted: Fri Feb 25, 2011 6:20 pm
Yes it's correct, because it has been imported to Switzerland in the 30s and after than the car has been returned to the factory (engine problems)
PostPosted: Fri Feb 25, 2011 7:27 pm
I dont remember it being returned with engine problems,when i sold it ,it had no engine.
PostPosted: Fri Feb 25, 2011 8:03 pm
#54206 - Bucar (CH) returned and dismantled
PostPosted: Fri Feb 25, 2011 8:41 pm
That is 206, not 216.
Was 216 not one of the cars that you assembled, Lazarus?
PostPosted: Fri Feb 25, 2011 9:03 pm
As I said in my previous note,I assembled the car .it was not returned to ME with engine problems !
PostPosted: Sat Feb 26, 2011 8:40 am
206 and 216 are not the same. 206 was returned in the 30s to Bugatti. I wonder what happend with the frame. Went into a type 55?
PostPosted: Sat Feb 26, 2011 9:43 am
It hasn't been returned to you John, because dad hasn't had engine problems with it, and it would be very hard to complain about the engine when you sold us a cylinder block and numerous bits! Correct me if I'm wrong, but my understanding was that the plate was an original un-numbered plate, stamped with a new Type 54 series number, the number not having been used or allocated by the factory? Of course I may have completely the wrong end of the stick.
Daniel Hicks
PostPosted: Sat Feb 26, 2011 10:16 am
Daniel Hicks
The plate is a BOC one or french but recent manufacture,not original.I stamped the number so as not to confuse the issue.This is clearly an impossible number for a T54.Have you driven dads car Daniel? I had five years of genuine pleasure with this car.I had to lift off twice going up Brooklands test hill ! Otherwise I was in danger of going into orbit without a spacesuit.Straight lines were not a problem but bends did require common sense.
PostPosted: Sun Feb 27, 2011 6:17 pm
Daniel Hicks
Dear Daniel,I hope that you and your family are ok after the earthquake.I only heard today.
PostPosted: Mon Feb 28, 2011 9:45 am
Thanks John,
We are all ok, being almost the other end of the country from the earthquake. All family are ok. From the reports at our Bugatti meeting on the weekend, all Bugatti owners in Christchurch that we have had contact with are ok too. A horrible time for all down there, and will have a huge effect on our small nation.
Re 54216, no i've not driven it, but have spent much time in the passenger seat. Fantastic toy, great fun, if slightly scary, even from the passenger seat! What it would be like with the blown 4.9 in it one can only imagine! A type 50 will be a nice, if slightly more civilised alternative.
Daniel
PostPosted: Mon Feb 28, 2011 6:18 pm
dhic001 wrote:
Thanks John,
Daniel
a few T54 drivers died at the wheel....not the most useable Bugatti.Very scary yes,and that was just with the Jaguar 3.8 litre motor,as you say a full blown T54 must be terrifying.
