It is currently Fri Oct 02, 2026 11:35 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Double ignition or not ?
PostPosted: Tue Jun 29, 2010 6:50 am
This is quite some rework on the block, wouldn't it be a better idea to fit a V12 engine in a type 51 block? :mrgreen:
PostPosted: Tue Jun 29, 2010 7:19 am
How does that look with regard to the exhaust pipes ? Is there space to remove the plugs [without removing the exhaust branch-although that may be an acceptable requirement to achieve a better burn pattern.]
PostPosted: Tue Jun 29, 2010 9:24 am
I dont think that space would be a problem having looked at photos,although I would not like to remove the plugs with a hot motor !
PostPosted: Tue Jun 29, 2010 12:52 pm
How much better will the engine runn , with the plug at the exaust side ? Has anyone tried it already ?
PostPosted: Tue Jun 29, 2010 3:21 pm
I've read that those Chevrolet LS1 motors kick out some serious horsepower, perhaps one could be cast into a kind of rectangular alluminium block to like like a type 35. Not strictly speaking a geniune Bugatti mod, but what the hell...
PostPosted: Tue Jun 29, 2010 4:24 pm
My Type 40 had twin ignition and was noticably faster than my T37.Bugatti tried plugs on both side of the prototype royale block as you know Greg.So why are you agin it?
PostPosted: Tue Jun 29, 2010 8:54 pm
And Bugatti tried double ignition on both sides of the Prototype Type 46 also...
PostPosted: Tue Jun 29, 2010 9:46 pm
if Bugatti tried it with the Royale and the 46 engine , and did not use it later , there must be a reason for .
PostPosted: Tue Jun 29, 2010 10:13 pm
Yes but Ettore did many silly things.
PostPosted: Tue Jun 29, 2010 11:12 pm
if I ask my friends in the Alsace question like , why did Bugatti do it this way ? Many times the answer is , " he was a real talien " . :wink:
