It is currently Fri Oct 02, 2026 11:23 am
Post new topic Reply to topic  [ 120 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Tue Oct 10, 2006 11:26 pm
That makes you a magician!
No, i'm an electrician but my boss thinks were all magicians.
PostPosted: Sat Oct 14, 2006 7:58 pm
The lobes are all cut on both cams. When i decide how i am going to drive the distributors i will cut off the stock on the back. I also put a photo of all the parts together as of today.
PostPosted: Sun Oct 15, 2006 12:05 pm
Very impressive, Steve. Must have been a hell of a job till so far.
I see you have also made cam covers already. Very nice.
Not bad for a magician... :D
PostPosted: Sun Nov 26, 2006 9:07 pm
Not much to report. I have been working too much.
Made the valve guides for the head. I will start on the valves tommorrow.
Photo's have been posted to my album of course.
PostPosted: Mon Nov 27, 2006 9:43 am
It's a shame working takes so much spare time...
What was the valve diameter? 3/8"?
PostPosted: Tue Nov 28, 2006 1:00 am
Just a hair under.
.370 diameter at the head. The stem off the head is .125 or 1/8 and the stem where it rides in the guide is .1875 or 3/16. Total length 1s 1.700.
P.S. I lied. I did not start the valves today. I'm looking to borrow a press to install the guides so i'll need a few more days.
PostPosted: Wed Nov 29, 2006 2:23 am
Ok, Valve guides are in and NOW i'm going to make valves. Soon!
PostPosted: Wed Nov 29, 2006 10:05 am
It is going to look like a real engine, Steve. Can't wait till the moment the head goes on the block.
PostPosted: Thu Nov 30, 2006 12:29 am
Me too!!
PostPosted: Fri Dec 15, 2006 1:57 am
I put up three photo's of the valves. They are finally done. Will be some time before i can continue. Work is going to pick up for a few weeks here.
What should i make next?
PostPosted: Fri Dec 15, 2006 10:56 am
2 things at least at this stage:
-a gear train to actuate the cams (or use a chain)
-valve covers
Then a carburettor, I guess, and intake manifold. Do you plan on making it supercharged? Then another gear train for the compressor, the compressor itself, and a blow of valve. (otherwise you could get away with making a dummy compressor.)
Some odds and ends: Engine bearers, water pump, etc.
How do you plan on cooling and lubricating the thing anyway? It is quite a large engine, when running, it will probably generate quite some heat, and power. Perhaps making a water-brake is an idea? That at least keeps control of the revs.
Don't forget a damper against the noise.
PostPosted: Sat Dec 16, 2006 1:11 am
I cant make it supercharged unless i learn how to cast aluminum SO i think i will put 4 OFFY trumpet style carbs on the side. Or i may try to modify a pair of weed wacker carbs to look more like bugatti carbs and make them updraft. That raises a question.
PostPosted: Sat Dec 16, 2006 1:22 am
-valve covers
The cam drive will be a timing belt. There are sources on the net for exactly what i need but no one local. I would like to walk into a store and get the proper belt the first time.
Valve covers are made. Review the photos. I think i will cut off the cam gear cover portion and try to make some that look more like the real thing.
PostPosted: Sat Dec 16, 2006 1:31 am
Cooling - I plan to make the four plates for the cylinder section and oil pan section. When i run the engine i will put two covers on the cylinder section that are finned and the air blowing from the fan should cool the engine.
Lubricating - I plan to mix oil with the gas to lube the cylinders. A dab of lithium on the cam lobes should take care of the cam. The rest is roller bearing.
Damper against the noise - NEVER!! The two pipes will come together like the real thing. After that there will be no muffler.
PostPosted: Thu Dec 21, 2006 9:49 pm
The head is completed. I added 1 new photo.
Next i will press on with the pistons, rods, and rings. My friend has also bought a welder for aluminum. He is almost good enough to let him make stuff for me so instead of the oil pan being one giant chunk, i think i will try to fab up plates and have him weld it together. Save a nice piece of aluminum.
It's moving along!
