It is currently Fri Oct 02, 2026 8:08 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
 Post subject: Chassis drawings
PostPosted: Tue Jun 28, 2011 11:58 am
has anyone ever checked the chassis drawings for example t35 and t41 with a cad programm ?
 Post subject: Re: Chassis drawings
PostPosted: Tue Jun 28, 2011 12:16 pm
There was a discussion some time ago, on the drawings of the T35, where the Brits changed some dimensions to make the drawings unsuitable for production.
I never entered the data in CAD, so personally I do not know.
Stuart Brown entered the complete T35 into cad (3D) so if there were errors, he must have found them. (he found very little)
See: viewtopic.php?f=1&t=420
Gerald Wingrove did the same for the T41 (in 2D) but these were drawings from his own observations, so most likely are not 100% correct.
PostPosted: Tue Jun 28, 2011 1:22 pm
I do not belive the story that the brits did change some dimensions to make the drawings unsuitable for production. Look , how many dimensions must I change to stop production of this part ? They made drawings with mistakes , after over 20 years driving Jaguars , I know this mistakes are not done on purpose . The Molsheim drawings have mistakes , in the t35 and t41 , the radiuses do not fit together .
PostPosted: Thu Jun 30, 2011 2:01 pm
What radius is different on the type 41?
PostPosted: Thu Jun 30, 2011 6:01 pm
in the drawing 41ch216 radius at the rear end is 60mm ?
PostPosted: Fri Jul 01, 2011 5:00 am
I did. there was 1 error....a radius if I remember correctly....but I don't remember which one.
Here is a partial view from one of my CAD drawings.
PostPosted: Sat Jul 02, 2011 9:07 am
So what's the problem with the radius being 60mm - its just a fillet, it doesn't fit into anything.
PostPosted: Sun Jul 03, 2011 2:11 pm
If you think so . If I build a Bugatti part , it has to be like the original and not fantasy . If I do not care about it , I can change any dimension . It looks like the drawing 41ch216 is full of mistakes .Is there any other t41 drawing for the chassis ? maybe Bugatti did not use 41ch216 .
PostPosted: Mon Jul 04, 2011 8:23 am
Udo - What are you on about this time?
PostPosted: Mon Jul 04, 2011 12:31 pm
If you take the chassis drawing 41ch216 and look at original chassis fotos , suddenly there are some questions .
PostPosted: Mon Jul 04, 2011 12:33 pm
Maybe you can make a scan of the drawing, as well as posting a photo of the actual chassis?
That way also those few of us who do not have access to 41CH216 can see what this is about?
PostPosted: Mon Jul 04, 2011 1:09 pm
I will look , if I can show a cad drawing , have to change the file to something .
PostPosted: Mon Jul 04, 2011 1:20 pm
you can send it to me, i will make it available (herman at bugattibuilder dot com)
PostPosted: Mon Jul 04, 2011 1:28 pm
dwg or dxf ?
PostPosted: Mon Jul 04, 2011 3:26 pm
voila
Users browsing this forum: No registered users and 436 guests
