It is currently Thu Oct 01, 2026 4:11 pm
 Post subject: Speaking of Posts.
PostPosted: Thu Nov 20, 2008 4:01 pm
On the list of Top 10 Posters, I, Johan now occupy the number 4 spot. Which means I'm either a valued contributor, or, as Jaap can testify, I just won't shut-up.
Go ahead, post a reply ; you know you want to.
Johan Buchner Esq.
 Post subject: reply
PostPosted: Fri Nov 21, 2008 9:31 am
:D ok i will :D
PostPosted: Fri Nov 21, 2008 10:35 am
I am still unbeaten... :D
PostPosted: Fri Nov 21, 2008 11:12 am
Of course you should be, if you react to each post with a polite "thank you for the post" post, you post the same number of posts that all other posters will post together.
 Post subject: la politesse
PostPosted: Fri Nov 21, 2008 11:43 am
then you should be twice as polite :D
PostPosted: Fri Nov 21, 2008 11:14 pm
If every post was full of wisdom, what a diferent world we should live in. :roll:
PostPosted: Sat Nov 22, 2008 3:38 pm
Johan, we should aim for quality not quantity!!
Regards, Bugwrench
PostPosted: Sat Nov 22, 2008 4:48 pm
Hi Bugwrench, nice to hear from you again! I disagree, if I only concentrate on quality I'll never post a damn thing! Ask anyone, it's true alas.
PostPosted: Sat Nov 22, 2008 5:35 pm
Well, I do not post just for posting. Bugwrench is right in a way. Although I do not feel that it is a problem on this forum.
Modelling forums are different in that way. You submit one picture, and about 25-50 people post reactions, varying from: "Ohhh, wow, nice, awesome, cool, etc".
This matter is also the reason I did not activate the ranking system on this forum. Using that gives users different ranks, depending on the amount of posts. Useless option.
