| Need engine information http://bugattibuilder.com/forum/viewtopic.php?f=7&t=57 |
Page 1 of 1 |
| Author: | stevehuckss396 [ Sun Feb 19, 2006 4:06 am ] |
| Post subject: | Need engine information |
I need all the information i can find on the Bugatti t50 engine. If you have photos, shop drawings, parts manuals, links to websites that someone documented a rebuild, a rusty old head behind your barn, anything! If i can find enough information I plan to build a 1/4 scale engine that will start and run. I have started to make a set of drawings for the crankshaft, rods and pistons, cylinders, ECT. Makes you realize how much you dont know. Here is what i do know. No of cylinders: 8 Bore x stroke: 86 x 107mm 3.3858 x 4.2125in Capacity: 4972cc or 303 ci BHP (approx): T50: 225; T50T: 200 RPM Limit (prudent): 4000 Camshafts: dohc Valves (per cylinder): 2 Camshaft drive: Front, spur train Crankshaft bearings: 9 plain, plain rods Supercharger: Roots, bevel driven Carburettor: 2 Zenith 36 or Schebler Ignition: Coil Plugs per cylinder: 1 Firing Order: 1, 6, 2, 5, 8, 3, 7, 4 |
| Author: | Herman [ Sun Feb 19, 2006 9:57 am ] |
| Post subject: | |
Crosspost, but a great project!, please continue here: http://www.bugattibuilder.com/phpBB2/viewtopic.php?t=58 |
