T 5 gearbox
http://bugattibuilder.com/forum/viewtopic.php?f=32&t=3936
Author:  Udolahr [ Sun Apr 29, 2012 2:02 am ]
Post subject:  T 5 gearbox
first prototype . Next step, build the bevel gears for the differntial .
Author:  Udolahr [ Sun May 06, 2012 7:49 pm ]
Post subject:  Re: T 5 gearbox
First test for the differential bevel gear .
Author:  tyr0 [ Wed Jun 27, 2012 12:26 pm ]
hey good photo of the straight-cut gears
a great job on your T5 gearbox
may i ask in your photo
is this a polymer for the bevel-wheel?
Author:  Udolahr [ Thu Jan 31, 2013 7:04 pm ]
Yes , this is a polymer . It is for testing the machine adjustment . After it is ok in polymer , I cut it in steel . All gears for the T5 are ready in steel .
Author:  tyr0 [ Fri Feb 01, 2013 3:01 am ]
certainly a great effort to build this T5 gearbox.
she will be a sporty car to drive
looks a close ratio gearbox
a very interesting project
thanks for sharing it is an inspiration
to me the box seems lightly built almost flimsy
its lay shaft is a narrow diameter
Author:  Lazarus [ Fri Feb 01, 2013 6:46 pm ]
I suspect that these small shafts are for test assembly purposes.I think the real ones will be thicker.....
Author:  Udolahr [ Mon Feb 04, 2013 3:18 am ]
Right , this is a test assembly with a 25mm shaft . The real one has 42mm diameter .
Author:  Udolahr [ Thu Feb 07, 2013 10:36 pm ]
this is the new shaft 42mm diameter hardened and ground . With the new gears made from steel and case hardened .
Author:  Timeless [ Fri Feb 08, 2013 2:23 am ]
Nice work on these gears! Do you know how the gears were hardened in the 1920's ?
Author:  Udolahr [ Fri Feb 08, 2013 3:33 pm ]
Case hardening ,
Author:  Udolahr [ Thu Sep 19, 2013 12:26 pm ]
How the gearbox looks today . The bronze bushings are still missing .
Author:  Lazarus [ Thu Sep 19, 2013 1:10 pm ]
Super ! Gut arbeit.
