New pictures EB T37 Homebuild
http://bugattibuilder.com/forum/viewtopic.php?f=32&t=3881
Author:  Aviatiker [ Tue Feb 28, 2012 10:31 am ]
Post subject:  New pictures EB T37 Homebuild
Selfmade Dashboard on selfmade frame - Status 27.2.2012
Author:  gerrit [ Tue Feb 28, 2012 11:34 am ]
Post subject:  Re: New pictures EB T37 Homebuild
Great class, very beautiful. :)
Author:  Marek [ Tue Feb 28, 2012 2:58 pm ]
Hallo Aviatiker,
could you tell me please, what kind of metal sheet did you use? Is there anybody who has got an expirience in this subject? Of course I'm thinking about the forged chaisses.
Best regards
Marek
Author:  Aviatiker [ Wed Feb 29, 2012 10:19 am ]
Chassis: Steel ST360 4mm thick
Dashboard: Aluminium 4mm thick, the underconstruktion also Steel ST360 4mm thick.
Pictures under www.orc-austria.at "Projekte" - "T37"
Best wishes
Bernhard
Author:  Lazarus [ Wed Feb 29, 2012 11:16 am ]
Pictures under http://www.orc-austria.at "Projekte" - "T37"
Best wishes
Bernhard
Hi Bernard,Excellent work.A couple of questions,You could so obviously make this dashboard exactly like Bugatti,you clearly have the skill so why change the method of making it? and secondly why is there a flat area on the top of the chassis on the left [ as there should be on the right for the steering box.] Are you planning links [left hand drive ] steering ?
Author:  Aviatiker [ Wed Feb 29, 2012 2:13 pm ]
The differents makes easyler the MG Midget 1500 ccm to build in!
We make a steelconstruction for the engine. This construction is a element from the dashboard!
The plate is on the left and right. It is formed on because we dispose the same basic steelelement (Lasercut steel 4mm) left and right side. Later we can cut it!
Bernhard
Author:  Aviatiker [ Wed Feb 29, 2012 2:24 pm ]
Hallo Lazerus,
See you the picture "frame"
Bernhard
Author:  Aviatiker [ Wed Feb 29, 2012 2:28 pm ]
The drawing with components from MG Midget 1500 engine, gear and rear axle!
dashbord einbaumass.pdf [59.11 KiB]
Downloaded 2025 times
