It is currently Fri Oct 02, 2026 9:03 am
 Post subject: Original spark plugs used in T35?
PostPosted: Fri Aug 09, 2013 9:03 pm
What type of spark plugs were the T35 cars equipped with at the factory? And if available, can anyone post a picture of one for reference of a model build?
 Post subject: Re: Original spark plugs used in T35?
PostPosted: Thu Aug 15, 2013 3:03 am
OK, anyone know the original equipment manufacturer supplier of the plugs when the T35 was made?
PostPosted: Thu Aug 15, 2013 6:39 am
KLG perhaps. Or Champion
PostPosted: Sat Aug 17, 2013 3:42 am
Would these have been brass body or ceramic?
PostPosted: Sun Aug 18, 2013 8:19 pm
I see in the old advertisments that by 1928, Nerka is associated with racing victories. Champion in earlier ads, so Herman is probably correct...Thanks.
PostPosted: Mon Aug 19, 2013 7:49 am
surely as insulation is necessary to deliver the spark to the fuel, ceramic would be necessary and probably a metal body to screw into the block...with brass terminal or spring wire of the era.?
PostPosted: Mon Aug 19, 2013 9:14 am
Hope this helps.
PostPosted: Mon Aug 19, 2013 12:08 pm
3DE wrote:
Hope this helps.
I dont know what was fitted to T35 but they would have tried all available [just as we all do ] I do know what was fitted to the T251 because I was lucky enough to be given a full box of new boxed originals.These are Marchal "course"
PostPosted: Tue Aug 20, 2013 5:03 am
Thanks to all for the help! The images are perfect for me, and I had forgotten Marchal brands...Regards, Ron
