| bugatti collections http://bugattibuilder.com/forum/viewtopic.php?f=11&t=1016 |
Page 1 of 1 |
| Author: | horseshoe [ Thu Nov 13, 2008 11:37 pm ] |
| Post subject: | bugatti collections |
Is it an idea to form a list of musea and privat or other collections where bugatti's are on display? and this world wide. I like to collect all this info and create a list and map where to find what. This should also include the work of Rembrandt and the furniture of the father. I beleive that you will be amazed how many cars, objects and parts are swirling around on the globe. looking forward to receive comments. |
| Author: | Johan Buchner [ Fri Nov 14, 2008 10:44 am ] |
| Post subject: | |
This is a great idea. It's going to be a lot of work though. I wish you the best of luck. Regards Johan |
| Author: | Lazarus [ Fri Nov 14, 2008 8:41 pm ] |
| Post subject: | lists in general |
I wish someone would make a list of componants like conrods.With all the different lengths etc.It may sound daft but I am restoring a motor [all aluminium twincam 2000 litre 4 cyl ] partly machined and built by Bugatti but not a Bugatti design.The original conrods were aluminium and broke.I am quite sure that there must be a rod from some normal car which would work perfectly well! The cost of new rods is quite high and not really justified in this case.All I need are four rods the same center distance and about the right size bigend [one can remachine the crank to correct minor differences.] We could start the list now,my rods are 130mm center to center and bigend journal 58mm |
| Author: | Herman [ Fri Nov 14, 2008 9:36 pm ] |
| Post subject: | |
Should they be one-piece (Bugatti design) or multi-piece (normal design) I am sure the right conrod is somewhere out there... Should it be classic, or can it be more modern as well? One could ask around on different automotive forums. I do not think it is doable to organise all parts of all Bugattis in such a way that it will be searchable on dimensions. On the museum-thing. Of course for as much cars as possible the owner of the car is mentioned on the WIKI. Including museums. However, it is more difficult to generate the inverse list: Which cars are owned by which museum. To couple a map to it is even another story. Perhaps some good ideas for Bugattibuilder Version 3... |
| Author: | horseshoe [ Sat Nov 15, 2008 12:57 am ] |
| Post subject: | |
You can find lots of messurements on engine parts in catalogs of Vanwell or or Mahle as far as bearings concerns, we have still some older engine revision workshops with extremely old man who know extremely much about extremely old engines and usualy have lots of parts that can be used on more makes. There is also a belgian shop who makes them new as far as I know. |
| Author: | horseshoe [ Sat Nov 15, 2008 1:01 am ] |
| Post subject: | |
The museum list is not only for the bugatti exposure but also to make the collections more inviting and add the museum and collections in their whiole appearance to us petrolheads. |
| Author: | Lazarus [ Sat Nov 15, 2008 8:44 am ] |
| Post subject: | conrods |
Thank you all,the conrod is of course conventional as this engine has shell bearings like every modern car.I Know it is difficult for some of you to get your head round but this engine is 1962 ! Bugatti did not stop in 1939 |
| Author: | Johan Buchner [ Sat Nov 15, 2008 2:18 pm ] |
| Post subject: | |
Hi Lazarus Thank you for sharing your passion for the, as you put it, "post-Conway Bugattis" This neglected part of Bugatti history has long cried out for a champion, and now we have you. Speaking only for myself, ever since you have joined the forum I have started to take an interest in the T73 (The T252 might take a while longer, I suspect) and for that I am in your debt. It's learning new things which keeps me loyal to Herman's creation, and you bring a whole new dimension to the study of Bugatti. Thank you. With Gratitude Johan |
| Author: | Lazarus [ Sat Nov 15, 2008 3:00 pm ] |
| Post subject: | T73 |
I would be happy to write an article but do not know how to load it onto the site ! There is quite a lot of interesting detail in the wartime work of Ettore that should be more widely understood.He seems to have realised for the first time that you have to produce things economically [meaning quantity ]if you want to suceed in business.Just how he redesigned his icon parts like the front axle so as not to compromise his demand for beauty as well as function is quite astonishing. |
| Author: | Herman [ Sat Nov 15, 2008 4:13 pm ] |
| Post subject: | |
mail an article to me, and everything will be arranged... |
