Nice detail
http://bugattibuilder.com/forum/viewtopic.php?f=1&t=8218
Author:  Udolahr [ Tue May 17, 2016 4:19 pm ]
Post subject:  Nice detail
Bugatti T37 , Bronze plate riveted .
Author:  37quest [ Thu May 19, 2016 11:29 pm ]
Post subject:  Re: Nice detail
Yep that's a real hub!
Was a set on a kit of bits T37 in France a couple of years ago did you buy it?
Author:  Udolahr [ Sat May 21, 2016 3:04 pm ]
I bought some 37 parts with hubs years ago . But this is a complete 37 and I must replace the hub , condition is to bad . Most original hubs are too bad to use , only found 2 good ones .
Author:  Lazarus [ Thu May 26, 2016 11:56 am ]
I have one original NEW front hub for T37 complete with brass plate as shown in your photos.
Author:  Udolahr [ Thu May 26, 2016 8:33 pm ]
A little bit to late ,I got 2 good ones . . What about welding the spline area and cut new splines ? Has anybody done this before ?
Author:  Lazarus [ Fri May 27, 2016 11:34 am ]
Very Naughty Udo ! However yes I have done something similar when I had two RH hubs and wanted one of each. I welded up the threaded portion and remachined the other hand. This was twenty years ago and the car is still driving as far as I know.
Author:  Udolahr [ Sat May 28, 2016 2:49 pm ]
I believe this Bugatti hubs are not high quality steel like a chrome moly , it is this normal ad3 about 70 kg steel . So welding is no problem .
