It is currently Thu Oct 01, 2026 5:33 am
 Post subject: 4928
PostPosted: Fri Apr 11, 2014 12:22 pm
Where is 4928 today ?
 Post subject: Re: 4928
PostPosted: Fri Apr 11, 2014 1:21 pm
See 4928 on bugattiregister.com
PostPosted: Fri Apr 11, 2014 2:36 pm
there is no info where the car is today
PostPosted: Fri Apr 11, 2014 4:19 pm
Isn't it with Walter Rothlauf in Germany? Also known as "4696" when owned by Haajanen. Or is this a trick question?
Cheers,
Sandy
PostPosted: Fri Apr 11, 2014 7:00 pm
4928/179 or 4928/191
PostPosted: Fri Apr 11, 2014 7:39 pm
179 is 4928
191 was 4923 (now has engine 60 ex-4611) at Schlumpf.
Sandy
PostPosted: Fri Apr 11, 2014 8:32 pm
Where is this car ? I got the info it is in a museum in Molsheim , can it be ?
PostPosted: Sat Apr 12, 2014 7:32 am
4928 in Mühlhausen mit Motor und Chassisplatte 4611
4611 mit Motor und Chassisplatte 4928 in Mühlhausen
PostPosted: Sat Apr 12, 2014 12:37 pm
Wenn 4611 der falsche ist , wo ist der echte ?
PostPosted: Sat Apr 12, 2014 12:45 pm
see above
PostPosted: Sat Apr 12, 2014 1:03 pm
Dann ist der echte bei W. Rotlauf ?
PostPosted: Sat Apr 12, 2014 1:42 pm
#79 Klausenrennen 1930, Hans Stuber (CH) 1st : 4923/191 or 4928/191 ?
PostPosted: Sun Apr 13, 2014 6:25 am
nein, es gibt zwei 4928
PostPosted: Sun Apr 13, 2014 9:07 am
Selon la Préfecture du Bas Rhin 1974-NV (F) a été attribué au chassis 4923 le 28 mars 1929 et utilisé sur le 4928 et 1975-NV (F) a été attribué au châssis 4928 le 28 mars 1929 et utilisé sur le 4923
4928 with 179 engine and carte grise of 4923 (1974-NV), now Walter Rothlauf car
4923 with 191 engine and carte grise of 4928 (1975-NV) , now with 60 ex-4611 Schlumpf car
1974-NV is on 4928/179 sold to Jean de l’Espée as 4923 (with carte grise of 4923)
PostPosted: Mon Apr 14, 2014 12:17 pm
