First test run of Type 73C engine
http://bugattibuilder.com/forum/viewtopic.php?f=1&t=4129
Author:  Lazarus [ Mon Oct 22, 2012 8:52 pm ]
Post subject:  First test run of Type 73C engine
Well it has taken many years but here is the first test run of my T73C engine.
Author:  minime [ Mon Oct 22, 2012 9:01 pm ]
Post subject:  Re: First test run of Type 73C engine
Sounds great.
Congratulations. :D
minime
Author:  Marek [ Mon Oct 22, 2012 9:06 pm ]
THANK YOU JOHN! CONGRATULATION! I'm very pleased. Nice to hear it. Great!
Author:  Herman [ Tue Oct 23, 2012 6:51 am ]
Electric engine?
Just joking, it sounds agressive without the dampers. Can;t wait to see it in the car.
Author:  onebugatti [ Sat Oct 27, 2012 6:11 pm ]
Post subject:  BFB
Brillant ! Finially ! Bravo !
Author:  Lazarus [ Sat Oct 27, 2012 7:02 pm ]
Post subject:  Re: BFB
onebugatti wrote:
Well it has taken many years but here is the first test run of my T73C engine. http://www.youtube.com/watch?v=s09FS4fjjdY
,Thank you all for the kind comments,here is another u tube clip which may amuse you.
Author:  Herman [ Sun Oct 28, 2012 11:11 am ]
My suspicision still is that it is an electrical engine. Why the 2 batteries otherwise? :)
Author:  Lazarus [ Sun Oct 28, 2012 3:33 pm ]
Two batteries=24 volts on 12 volt starter.Result=very fast turnover of engine.As the carburettor is 3 KMs from the combustion chamber it helps.
Author:  davids [ Sun Oct 28, 2012 5:08 pm ]
wonderful moment when it first started..enjoy as it is the unique moment..
presume when in the body it will use a kygas system rather than 24v...?
Author:  Lazarus [ Sun Oct 28, 2012 6:46 pm ]
There is no onboard electric starter so I will have to fit the kigas system,otherwise I will have to tow it for miles.Sadly I forgot to drill the boss on the manifold for Kigas! I will have to take off the manifold and drill it.There is a side input for a remote electric starter,but with so many other things to sort out I never got around to finishing it.There is a bevel drive gear on the clutch to gearbox shaft.I notice that the same system is used on the "Cork" car at Goodwood.
