| Front axel question ? http://bugattibuilder.com/forum/viewtopic.php?f=1&t=2611 |
Page 1 of 2 |
| Author: | Udolahr [ Thu Oct 20, 2011 1:05 pm ] |
| Post subject: | Front axel question ? |
Only the GP cars have a hollow front axel ? What about the Royale ? |
| Author: | Bugwrench [ Thu Oct 20, 2011 2:45 pm ] |
| Post subject: | Re: Front axel question ? |
Udolahr wrote: Only the GP cars have a hollow front axel ? What about the Royale ? Hollow with a 40mm hole. Bugwrench |
| Author: | Lazarus [ Thu Oct 20, 2011 4:27 pm ] |
Udolahr wrote: Only the GP cars have a hollow front axel ? What about the Royale ? T46 and T50 have hollow axles. |
| Author: | Udolahr [ Thu Oct 20, 2011 5:37 pm ] |
maybe all have hollow axels ? |
| Author: | Herman [ Thu Oct 20, 2011 7:08 pm ] |
no |
| Author: | Bugwrench [ Thu Oct 20, 2011 7:17 pm ] |
Udolahr wrote: maybe all have hollow axels ? PLease be more specific. What is 'all'? Bugwrench |
| Author: | Udolahr [ Thu Oct 20, 2011 8:22 pm ] |
T37 has a solid axel , so how are all the others ? |
| Author: | Theesse [ Thu Oct 20, 2011 9:13 pm ] |
Making the axles hollow was (and still is) a matter of price. So the racers and luxury cars had hollow axles and the tourers and 'cheaper' racers just solid. Just a shame it cannot be seen once it is mounted under a car... |
| Author: | Udolahr [ Fri Oct 21, 2011 11:10 am ] |
are there any small holes drilled to check the wall thickness ? |
| Author: | 37quest [ Fri Oct 21, 2011 2:35 pm ] |
I don’t think it was seen as necessary as they were forged not cast, on a GP the holes where the forging was closed over is a by product of the forging process and visible on the end of the king pin eye. Where there is a hole in this position that has clearly been drilled the axel is almost always a reproduction and if hollow probably cast. |
| Author: | Lazarus [ Fri Oct 21, 2011 4:53 pm ] |
Udolahr wrote: are there any small holes drilled to check the wall thickness ? There would be little point as the GP axles are machined both inside and out.You have to remember that the axle starts out as a straight forging.Boring through and then machining the center part of the outside means that the wall thickness must be correct. |
| Author: | Bugwrench [ Fri Oct 21, 2011 5:24 pm ] |
Lazarus wrote: Udolahr wrote: are there any small holes drilled to check the wall thickness ? There would be little point as the GP axles are machined both inside and out.You have to remember that the axle starts out as a straight forging.Boring through and then machining the center part of the outside means that the wall thickness must be correct. And any out of line drilling is visible in the springboxes! Bugwrench |
| Author: | Udolahr [ Fri Oct 21, 2011 6:44 pm ] |
some Molsheim drawings show 1,5 mm holes drilled in several places . " TROU DE REPERE 1,5mm " |
| Author: | davids [ Fri Oct 21, 2011 7:22 pm ] |
"some" please be specifique and say which drawings give a point as it may be mis read or mis understood.if presumably you know which ones. accuracy in the question is important to avoid misunderstandings and innacuracies or annoyances in the answers. |
| Author: | Bugwrench [ Fri Oct 21, 2011 7:34 pm ] |
Udolahr wrote: some Molsheim drawings show 1,5 mm holes drilled in several places . " TROU DE REPERE 1,5mm " Yes, but you forgot to mention that this is followed by: 1,5mm profondeur! Be aware that a "trou de repère" should be considered as a professional alternative for the centerpoint marking. Bugwrench |
| Page 1 of 2 | All times are UTC + 1 hour |
