It is currently Thu Oct 01, 2026 7:47 pm
 Post subject: opening a rear diff unit...
PostPosted: Fri Sep 23, 2011 2:48 pm
Hello,for a rear differential, after undoing the small locking screw and securing wire and hub bearing rings, how does one take out the demi arbre,
half shaft ..is there a technique or special tool , to split the diff body ?
thanks for ideas.
 Post subject: Re: opening a rear diff unit...
PostPosted: Fri Sep 23, 2011 3:38 pm
thanks for ideas.
There are no special tools required to dismantle or reassemble a Bugatti diff.The half shaft is threaded on both ends,it is necessary to remove the locking pin and nut on the inner end to remove the halfshaft.There is a slight taper and keys into the differential gear.
PostPosted: Mon Sep 26, 2011 7:46 pm
It took an ancient 3 legged puller with lots of pressure and a mighty wack with a lump hammer ,but thank you for the technique- it is apart..and now understandable.
David
