It is currently Fri Oct 02, 2026 11:48 am
 Post subject: Question ?
PostPosted: Wed Jul 06, 2011 11:58 pm
How is the center tube conected with the autside spring hänger ?
 Post subject: Re: Question ?
PostPosted: Thu Jul 07, 2011 9:06 am
A bolt goes through the spring hanger and the tube. Remove the spring and you will see it. Thought you would know that.
PostPosted: Thu Jul 07, 2011 11:30 am
can you show any foto how it looks ? Has the bolt a counter sunk head , so the spring hanger is flat underneath ? What diameter can it be , like 8mm ? Has the inside tube a thread or is a nut inside ?
PostPosted: Thu Jul 07, 2011 4:58 pm
Both spring hanger and tube has a thread.
PostPosted: Thu Jul 07, 2011 6:19 pm
counter sunk ? 8 or 10 mm ? Foto shows T28
PostPosted: Fri Jul 08, 2011 10:50 am
14mmX 1.25P
PostPosted: Fri Jul 08, 2011 11:16 am
OK , 14mm . What about the counter sunk head ? Or is a hole in the spring for the bolt head ?
PostPosted: Sun Jul 10, 2011 9:04 pm
T44 , T50, T41 has a rivet with a counter sunk head .
