Bearings for T37
http://bugattibuilder.com/forum/viewtopic.php?f=1&t=2349
Author:  Udolahr [ Tue Mar 01, 2011 1:29 am ]
Post subject:  Bearings for T37
It is not so easy to use centrifugal force to get the babbit in to the first bearing . Babbit bearings made with centrifugal force are much better compare to pure the babbit static .I use the same device for centrifuge and rough machining .
Author:  nicefloor [ Thu Mar 03, 2011 3:32 pm ]
Post subject:  Re: Bearings for T37
Do you poor the babit in while the fixture is spinning?
Author:  Udolahr [ Fri Mar 04, 2011 1:26 am ]
first spinning with maybe 50 rpm and heating it up , after the babbit is in and the temparature is OK go to 1000rpm .But there are some secrets . Line boring the front bearing . About 1mm has to go .
Author:  Udolahr [ Sat Mar 05, 2011 7:02 pm ]
front bearing is ready
Author:  Lazarus [ Sat Mar 05, 2011 7:27 pm ]
I hope that you have the correct Bugatti nuts for these main bearings Udo.
Author:  Udolahr [ Sat Mar 05, 2011 10:22 pm ]
one of the motor experts did change the 7 mm studs to 8mm with modern nuts . I will use the 8mm studs but bugatti nuts . Do you have a foto how it looks original ?
Author:  Lazarus [ Sat Mar 05, 2011 10:52 pm ]
all the nuts are traditional Bugatti castle nuts with built in washers.I probably have these all in stock.
Author:  Udolahr [ Sun Mar 06, 2011 12:56 am ]
for the main bearing studs , I prefer grinded washers with castle nuts .
Author:  Lazarus [ Sun Mar 06, 2011 10:04 am ]
Then it would not be a Bugatti Udo ! It would be an Udobugatti.The Bugatti club had some 8mm nuts made twenty years ago by a mistake.They may still have them.
Author:  Udolahr [ Sun Mar 06, 2011 2:49 pm ]
OK, I will think about it , but Udobugatti sounds good . I like it , "The Bugatti club had some 8mm nuts made by a mistake " . The alluminium crankcase is a new one from England , but I had to make a line bore for the main bearings . Bearings diameter 69mm
0,15mm out of round . Can anybody tell me how to make a egg shaped line bore ?
Author:  Lazarus [ Sun Mar 06, 2011 4:08 pm ]
Very clever these english,surely You germans know how to do this Udo ? I though you could do everything !
Author:  Udolahr [ Sun Mar 06, 2011 5:17 pm ]
If you ask me to make a egg shaped line bore , I have to think about it how to do it . In the moment I don`t know .
Author:  Udolahr [ Sun Mar 06, 2011 7:23 pm ]
almost ready .
Author:  nicefloor [ Tue Mar 08, 2011 11:14 pm ]
Its looking great Udo. Nice work.
