It is currently Thu Oct 01, 2026 7:46 pm
 Post subject: T 57
PostPosted: Thu Jan 13, 2011 11:56 pm
who knows the T57 and T 57s back axel ratio ? Is it the same ?
 Post subject: Re: T 57
PostPosted: Fri Jan 14, 2011 4:14 pm
the early T57 backaxleratio is 12x50.
the revised version has 11x46.
the T57S is the same 11x46.
PostPosted: Fri Jan 14, 2011 7:28 pm
In the same line: What is the material thickness of a T57 or T57S frame?
PostPosted: Fri Jan 14, 2011 7:35 pm
Thank you for the info Pehess . Do you know the modul ? Can it be that the 57S has modul6 and the normal 57 has modul5 ?
T57S , I think has 4,5mm material . Anybody has the drawing ?
PostPosted: Fri Jan 14, 2011 7:40 pm
T57 = 4.16 [later 4.18]
T57S = 4.18
PostPosted: Sat Jan 15, 2011 12:06 pm
the t57s chassis is made from 3,5mm material. it is not from Molsheim plant.
The modul ????
PostPosted: Sat Jan 15, 2011 1:39 pm
ratio 4,16:1 or 4.18:1 is the same . So , the dimension of the diff did change or the modul . Anybody knows if the diameter of the diff did change ? The later ones have allu ribs autside ?
PostPosted: Sun Jan 16, 2011 11:15 am
I think the differential of T57 and T57S is the same.
