| T 57 http://bugattibuilder.com/forum/viewtopic.php?f=1&t=2298 |
Page 1 of 1 |
| Author: | Udolahr [ Thu Jan 13, 2011 11:56 pm ] |
| Post subject: | T 57 |
who knows the T57 and T 57s back axel ratio ? Is it the same ? |
| Author: | pehess [ Fri Jan 14, 2011 4:14 pm ] |
| Post subject: | Re: T 57 |
the early T57 backaxleratio is 12x50. the revised version has 11x46. the T57S is the same 11x46. |
| Author: | Herman [ Fri Jan 14, 2011 7:28 pm ] |
In the same line: What is the material thickness of a T57 or T57S frame? |
| Author: | Udolahr [ Fri Jan 14, 2011 7:35 pm ] |
Thank you for the info Pehess . Do you know the modul ? Can it be that the 57S has modul6 and the normal 57 has modul5 ? T57S , I think has 4,5mm material . Anybody has the drawing ? |
| Author: | Uwe [ Fri Jan 14, 2011 7:40 pm ] |
Udolahr wrote: who knows the T57 and T 57s back axel ratio ? Is it the same ? T57 = 4.16 [later 4.18] T57S = 4.18 |
| Author: | pehess [ Sat Jan 15, 2011 12:06 pm ] |
the t57s chassis is made from 3,5mm material. it is not from Molsheim plant. The modul ???? |
| Author: | Udolahr [ Sat Jan 15, 2011 1:39 pm ] |
ratio 4,16:1 or 4.18:1 is the same . So , the dimension of the diff did change or the modul . Anybody knows if the diameter of the diff did change ? The later ones have allu ribs autside ? |
| Author: | pehess [ Sun Jan 16, 2011 11:15 am ] |
I think the differential of T57 and T57S is the same. |
