It is currently Fri Oct 02, 2026 12:26 pm
 Post subject: Keeping the water and oil apart
PostPosted: Wed May 18, 2011 3:23 am
What is recommended as a sealant for the joint between the block and cambox -in this instance on a three valve four-cylinder engine. I am using an aluminium closing plate.
 Post subject: Re: Keeping the water and oil apart
PostPosted: Wed May 18, 2011 1:42 pm
Hylomar
PostPosted: Wed May 18, 2011 2:17 pm
Locktite 518 is far better than Hylomar [which I used for 20 odd years] It is remarkably good at sealing.Remember that on a Bugatti engine with screwed in valve guides,they need to be in and stay in their positions after grinding in the valves.The threads are not a very good centering device.
PostPosted: Thu May 19, 2011 1:52 am
Hylomar is not made for cars , it is for jet-engines.Normal threads are not very good for centering , but if I make them , it is in the center . I grind the valves in place , no need to take the guides off again .
PostPosted: Fri May 20, 2011 3:03 am
Many thanks for your help.
PostPosted: Fri May 20, 2011 8:15 am
British engineers invented the jet engine. :wink:
PostPosted: Fri May 20, 2011 10:52 am
Well I never ! and I had always thought that it was an ancient Greek.
PostPosted: Sat May 21, 2011 1:43 pm
first jet engine was made in Greek , over 2000 years ago with steam .Elling in Norway 1903 , de Karavodine in Russia 1906 . I think we all know who made the first successful ones .
